Circuit breaker or fuse requirements
You must use a circuit breaker or fuse that is sufficient to support the plasma cutting system.
For main feed protection, choose a circuit breaker or fuse that is large enough to withstand all branch-feed loads for both inrush and steady-state current. Refer to Input power requirements for the recommended time-delay fuse sizes.
As an installer or user, you must choose time-delay fuses and circuit breakers that can withstand inrush current that is up to 30 times the rated input current for 0.01 seconds and up to 12 times the rated input current for 0.1 seconds.
- Local line conditions (such as source and line impedance and voltage fluctuations)
- Product inrush characteristics
- Regulatory requirements
Always follow the national and local electrical safety requirements for your location, including requirements for correct electrical system design and installation. Speak with a licensed electrician for more information about the codes in your location.
If time-delay, high-inrush fuses are not permitted at your site because of national or local codes, use a motor-start circuit breaker or equivalent.
