Estados de válvulas por ID de proceso
La tabla muestra si la válvula está activa (ON) o inactiva (OFF) para diferentes tipos de bloques (preflujo, flujo de corte, perforado) y gases en determinados procesos.
Tabla 1. Estados de válvulas por ID de proceso
ID de proceso: 1001, 1002, 1003, 1004, 1005, 1151, 1152, 1153, 1155, 1156
Tipo de bloque Gas V1 V4 V5 V6 V7 V8 V9 V10 V11 V12 B1 B2 B3 B4 B5 B8 B9 B10
Preflujo N2/Aire Apg. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Flujo de corte O2/Aire Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
Perforación O2/Aire Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 7001, 7004, 7005, 7007, 7008, 7009, 7010, 7011, 7012, 7013, 7018, 7020
Flujo de corte O2/O2 Enc. Apg. Apg. Apg. Enc. Apg. Enc. Apg. Enc. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 8001
Preflujo N2/N2 Apg. Apg. Enc. Apg. Apg. Apg. Enc. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Flujo de corte N2/N2 Apg. Apg. Enc. Apg. Apg. Apg. Enc. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Perforación N2/N2 Apg. Apg. Enc. Apg. Apg. Apg. Enc. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 9001, 9010, 9018
Preflujo Ar/aire Apg. Apg. Apg. Enc. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Flujo de corte Ar/aire Apg. Apg. Apg. Enc. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Perforación Ar/aire Apg. Apg. Apg. Enc. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 2051, 2054, 2057, 2100, 8004, 8005, 8006
Preflujo N2/N2 Apg. Apg. Enc. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Flujo de corte N2/N2 Apg. Apg. Enc. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Perforación N2/N2 Apg. Apg. Enc. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 2010, 2011, 2028, 2029, 2052, 2055, 2058
Preflujo N2/H2O Apg. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Enc. Apg. Apg. Apg.
Flujo de corte N2/H2O Apg. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Enc. Apg. Apg. Apg.
Perforación N2/H2O Apg. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Enc. Apg. Apg. Apg.
ID de proceso: 2053, 2056, 2059, 2060, 2061, 2062, 2063, 2064, 2065, 2066
Flujo de corte Mezcla/N2 Enc. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Apg. Apg. Enc. Apg. Apg. Apg. Enc. Enc. Enc.
Perforación Mezcla/N2 Enc. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Apg. Apg. Enc. Apg. Apg. Apg. Enc. Enc. Enc.
ID de proceso: 1201, 1203, 1206, 1251, 1252, 1253, 1254, 1255, 1281, 1282, 1283, 1284, 1285, 1286, 1287
Flujo de corte O2/Aire Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 1051, 7014, 7015
Preflujo N2/O2 Apg. Apg. Apg. Apg. Enc. Apg. Enc. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Perforación O2/O2 Enc. Apg. Apg. Apg. Enc. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 1101, 1102
Flujo de corte O2/Aire Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
Perforación O2/Aire Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 1103, 1104, 1105, 1106, 1107
Flujo de corte O2/Aire Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 7002, 7003, 7006
Flujo de corte O2/O2 Enc. Apg. Apg. Apg. Enc. Apg. Enc. Apg. Enc. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 2001, 2002, 2003, 2004, 2005
Preflujo N2/N2 Apg. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Apg. Enc. Enc. Apg. Enc. Apg. Apg. Apg. Apg.
Flujo de corte F5/N2 Enc. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Enc. Apg. Enc. Apg. Apg. Apg. Apg.
Perforación F5/N2 Enc. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Enc. Apg. Enc. Apg. Apg. Apg. Apg.
ID de proceso: 2006, 2007, 2012, 2013, 2014, 2015, 2024, 2025, 2026
Flujo de corte N2/N2 Apg. Apg. Enc. Apg. Apg. Apg. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Perforación N2/N2 Apg. Apg. Enc. Apg. Apg. Apg. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 2008, 2009
Preflujo N2/Aire Apg. Apg. Apg. Enc. Apg. Apg. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Flujo de corte Aire/aire Enc. Apg. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
Perforación Aire/N2 Enc. Apg. Enc. Apg. Apg. Apg. Apg. Apg. Enc. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 2016, 2017, 2018, 2019
Perforación Aire/aire Enc. Apg. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 2020, 2021, 2022, 2023
Flujo de corte F5/N2 Enc. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Apg. Apg. Enc. Apg. Enc. Apg. Apg. Apg. Apg.
Perforación F5/N2 Enc. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Apg. Apg. Enc. Apg. Enc. Apg. Apg. Apg. Apg.
ID de proceso: 9004, 9005, 9006, 9014, 9015, 9016, 9017
Preflujo Ar/N2 Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Flujo de corte Ar/N2 Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Perforación Ar/N2 Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 8007, 8010
Flujo de corte N2/Aire Apg. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Perforación N2/Aire Apg. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 9007, 9019
Preflujo Ar/aire Apg. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Flujo de corte Ar/aire Apg. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Perforación Ar/aire Apg. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 9008
Preflujo Ar/aire Apg. Apg. Apg. Enc. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Flujo de corte Ar/aire Apg. Apg. Apg. Enc. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 9002, 9003, 9009
Preflujo Ar/N2 Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Flujo de corte Ar/N2 Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Perforación Ar/N2 Apg. Apg. Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 1202, 1204
Flujo de corte O2/N2 Enc. Apg. Enc. Apg. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
Perforación O2/N2 Enc. Apg. Enc. Apg. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 2027, 2101
Perforación Aire/aire Enc. Apg. Apg. Enc. Apg. Apg. Apg. Apg. Apg. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 8002
Preflujo N2/N2 Apg. Apg. Enc. Apg. Apg. Apg. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 1205
Perforación O2/Ar Enc. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 1207
ID de proceso: 9011, 9012, 9013
ID de proceso: 1060, 1061, 7016, 7017
Preflujo N2/Aire Apg. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Perforación O2/Aire Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 1157
ID de proceso: 7019
Preflujo N2/O2 Apg. Apg. Apg. Apg. Enc. Apg. Enc. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 1288
ID de proceso: 1289
Flujo de corte O2/Ar Enc. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 2071, 2073, 2075
Preflujo N2/N2 Apg. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Enc. Enc. Enc.
Flujo de corte Mezcla/N2 Enc. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Enc. Apg. Enc. Apg. Apg. Apg. Enc. Enc. Enc.
Perforación Mezcla/N2 Enc. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Enc. Apg. Enc. Apg. Apg. Apg. Enc. Enc. Enc.
ID de proceso: 2072, 2074
Perforación Mezcla/aire Enc. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Enc. Apg. Enc. Apg. Apg. Apg. Enc. Enc. Enc.
ID de proceso: 2076
Preflujo N2 /Ar Apg. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Apg. Enc. Enc. Apg. Apg. Apg. Enc. Enc. Enc.
Flujo de corte Mezcla/aire Enc. Apg. Enc. Apg. Apg. Apg. Apg. Enc. Apg. Enc. Apg. Enc. Apg. Apg. Apg. Enc. Enc. Enc.
ID de proceso: 8011
ID de proceso: 9020, 9021
ID de proceso: 3001, 3006
ID de proceso: 3011
Preflujo N2/Aire Apg. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Enc. Enc. Apg. Apg. Apg. Apg. Apg. Apg.
Flujo de corte O2/Aire Enc. Apg. Apg. Enc. Apg. Apg. Enc. Apg. Enc. Enc. Enc. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
Perforación O2/N2 Enc. Apg. Enc. Apg. Apg. Apg. Enc. Apg. Enc. Enc. Apg. Enc. Enc. Apg. Apg. Apg. Apg. Apg.
ID de proceso: 3012
ID de proceso: 3016
ID de proceso: 3021
ID de proceso: 3026
ID de proceso: 2082
