Troubleshooting for a plasma power supply or torch communication fault (0-98-2)
An 0-98-2 fault code identifies a communication failure between the torch and the plasma power supply.
When this fault occurs, the SmartSYNC® torch is
not sending data to the plasma power supply, so the system cannot collect data about
the Hypertherm® cartridge. The problem can be
with the Hypertherm cartridge or with the
SmartSYNC torch. There can be a problem
with:
- The Printed Circuit Board (PCB) in the torch
- The torch lead
- The quick-disconnect receptacle
- The torch communication circuitry on the PCB in the plasma power supply
Fault codes and fault LEDs
| Fault code | Fault LEDs | Torch LED | Description | Stops the system from operating? |
| 0-98-2 |
ON |
Yellow |
A communication failure occurred between the torch and the plasma power supply. | No. You can continue to cut or gouge, but you must set the output current (A) and the operating mode manually. |
