The Torch Cap fault Light Emitting Diode (LED) illuminates when the
torch or Hypertherm® cartridge is not ready to cut or is not able to cut.
Fault codes and fault LEDs
| Fault code |
Fault LEDs |
Torch LED |
Description |
Stops the system from operating? |
| None |
ON
Yellow
The Hypertherm cartridge was off, the torch was disconnected, or the
torch was in the yellow lock (X) position during a
restart. |
Yes |
Corrective action for the Hypertherm cartridge and torch
Move the torch-lock switch to the green "ready to fire" position.
This fault can show when you do a restart while the torch-lock switch
is in the yellow lock (X) position.
Remove the Hypertherm cartridge, and reinstall it correctly.
Reconnect the torch to the plasma power supply, and do a quick
restart.
- Optional::
Machine torch: Lock and unlock the torch, or do a quick restart.
This fault can be caused by removing the Hypertherm cartridge without first
setting the torch-lock switch to the yellow lock position or setting
the power switch to OFF (O).
- Optional::
Mini machine torch: Do a quick restart.
setting the power switch to OFF (O).
If possible, do a test with a different torch that is known to work
correctly.
Push down the plunger in the torch head and then release.
If the plunger moves freely and goes back to its start position, speak to your
distributor or authorized repair facility.
There is possible damage in the torch or in the plasma power supply.
